Read an Arcade expression from a web scene into EB
656
11-21-2023 07:06 AM
GeorgeF
I use arcade in a web scene to calculate an expression and store the value as a temp attribute.
When I am using the widgets in EB, for example the "Button" widget and want to connect it to this temp attribute (as it contains a URL), this attribute field is not shown in the dropdown list of all the other attributes.
I suspect this is because of the expression calculation not transferred to EB?
Has anyone had a similar experience? Are there any proposed work-arounds? seems quite limiting to not be able to use these attributes in EB.
Thank you,
George
