Query Widget, how to show all selected feature in the map. Actions-->Show on Map
790
01-10-2025 04:58 AM
SanchezNuñez
Good morning,
I am selecting all the points inside a Municipality using the Query widget in EB. The result lists 7600  records , When I want to see the points selected in the map, I go to on Actions-->Show on Map, but it only shows a few, (1000) highlighted yellow.
How can I change this configuration to sow all the records selected highlighted the map.
Laura
by MVP Regular Contributor
I personally use the filter more than query widget.
My example is we have a tree layer. They are marked as planted or removed. I can filter to just show all planted trees and they all come up on the map just fine (thousands). Maybe try this widget instead?
SanchezNuñez
Thank you @Laura
I am testing a new widget the Select widget and this one highlights the selection.
