Publishing an Experience and securing it via login from Arcigs Online
266
07-28-2025 02:30 AM
Baral_lec
I tried to follow these steps, to secure an Experience via AGOL. FAQ: Is It Possible to Create Custom Widgets in ArcGIS Online?
I set the config.json:  clientId, that I obtained by creating a application in my organisations Agol, and I set as portalUrl the Url of that Agol.
"attributes": {
    "portalUrl": "https://*****.maps.arcgis.com",
    "isWebTier": false,
    "clientId": "ZZwh1GZDX2*****",
The experience makes requests to
 and receives {
"error": {
"code": 405,
"messageCode": "GWM_0005",
"message": "Method not supported.",
"details": []
and
https://****.maps.arcgis.com/sharing/rest/oauth2/platformSelf?f=json
and receives
"error": {
"code": 403,
"messageCode": "GWM_0003",
"message": "You do not have permissions to access this resource or perform this operation.",
"details": []
I assume these two failed requests stop the OAuth attempt. Is there anything else that you have to configure in your arcgis online instance?
TimWestern
MVP
Are you trying to secure an entire experience or are you trying to get a Custom widget to work?
