Print Service Custom Layouts NOT filtering on visible rows
1002
07-29-2024 04:55 PM
Ankitkhanna
Hi All,
I have create custom layouts in ArcGIS Pro 3.1 and published the print service following the instructions here to my Enterprise 11.1:
I got print service working.
I added following widgets on my Experience builder app:
  1. Print widget - configured with custom layouts.
  2. Filter widget - querying object id to filter and show only 1 feature on Map.
I am experiencing issue with with dynamic text fields in printed layout, layout is configured to show values to VISIBLE ROWS of MAP FRAME. But while printing, dynamic text populates for all features in MAP EXTENT even if the features are not visible (filtered out with filter widget).
Did anyone ran into this issue?
ShengdiZhang
Hi @Ankitkhanna ,
Currently, the Experience Builder print widget does not support dynamic text. You can follow the Support issue ENH-000161074 to track this feature.
As a workaround, you can publish custom print services that include reports. Below is a tutorial on how to publish such a custom print service:
https://www.esri.com/arcgis-blog/products/arcgis-enterprise/national-government/creating-a-custom-pr...
Regards,
Shengdi
Ankitkhanna
Hi @ShengdiZhang thanks for responding to this case. I am not report can be a solution as I want mapframe and attributes in single layout/page. But I will try this to test out if report works.
Ankit
