Popups in Experience Builder are not matching popups configured in Map Viewer.
4660
13
11-15-2023 09:35 AM
Labels (2)
apgis16
I configured popups in a simple web map. All I have is the title - no field lists or anything. However, the popup in Experience Builder shows a field list. I don't want to show any fields besides the one I have in the title section.
Thanks in advance!
IssyAmis
Hi @apgis16
Thanks for your question. I've given this a quick test and the pop ups seem to be working as expected for me so hopefully we can work out why this is not working for you.
Just to check, are you editing the pop up within the pop up tab in the web map viewer?
I assume your configuration looks similar to the above screenshot with all fields removed and just the title present? Could you confirm that once you save this web map and navigate to experience builder, the pop ups appear differently than within your web map?
Thanks!
Issy
apgis16
I removed the fields list in Map Viewer and just have a field in the Title section. However, when I turn on the popups in Experience Builder, it shows a field list.
IssyAmis
Hi @apgis16
If you refresh your web map, do the pop ups show as expected in the map viewer? Would you be able to send a screenshot of the pop up configuration within the map viewer and how it is showing in the experience builder?
Thanks!
KatieSelfEd
Hello - I've had this issue too (although in a web scene) but I found a workaround so thought I would post it.
In the 'configure pop-ups' window, deleting the 'fields list' item would result in this issue.
Instead if you keep the 'fields list' item and instead remove all of the fields so it is empty, then the pop-up will display without the list.
NBC
Hello,
We have the same issue using the Map viewer web maps in Experience Builder.  Seems that ExB is not reading the map viewer popup config properly.
The workaround works though thanks!
dsinha
Seems unbelievable that this has still not been fixed, but thanks for sharing the workaround @KatieSelfEd.
Catherine_Hodde-Pierce
Thank you so much! This worked for me, too, and I'm happy it was a simple fix. I agree with @dsinha, crazy that this hasn't been fixed yet...
amarcz_cc
ArcPro 3.5 Enterprise 11.2.
I am having an issue with Charts in the popup, where the option to 'Maintain Axis' is not maintained. If published through ArcPro to maintain axis at 100, it will show in the MapService as 100, it will show in the Feature Service as 100, it will show in a webmap as 100, but it will show as relative to the feature in an experience builder.
SarahBarks
Just replying to this as it is still an issue 2 years later! I used @KatieSelfEd 's suggestion and kept the field list but unticked the boxes and that does the trick, but surely that isn't how it's meant to work? @IssyAmis is this being looked at at all please?
