Poor Slow Performance with Experience Builder
11054
38
03-07-2025 08:33 AM
TD1
Created an Experience Builder app based on the same map/data that a WAB app was using. WAB is very quick panning/zooming but the Experience Builder app is painfully slow.
We all pay good money for these tools and this is unacceptable.
This needs to be resolved ASAP as users don't want to use the app as its slower on the supposed "new and improved" Experience Builder
berniejconnors
Here is my understanding of the problem.  The ArcGIS JS 4.x API requires WebGL 2.0 support on the end user's hardware.  To run WebGL 2.0 efficiently a GPU is required:
  • Older systems that do not have drivers or hardware (GPU) to support WebGL 2.0 will not be able to load an ExB app.
  • Systems that have a driver to support WebGL 2.0 but do not have a GPU will attempt to emulate a GPU with the CPU and perform very, very poorly.
Our solution was to publish an ExB app but to also retain our old WAB app to support users with old hardware.  We placed several warnings in the WAB app related to deprecated software.  Currently, about 9.7% of our users are still using the WAB app.
Bernie.
nicholsonc_electric
Is everyone still having these issues? Mine takes forever to load even with a computer that has the capabilities needed to load the maps in a timely manner. My users are not happy about the move to ExB when the WAB map worked perfectly for their needs. If anyone has found a solution to this let me know!
Thanks
Agrizz
Yup, have been migrating a very large WAB app (130+ layers) that works very well to XB which is significantly slower. It would be wise to reduce the # layers but this is a legacy product from before my time. Point is, it works well in WAB but is significantly slower in XB. Needs to perform better.
Agrizz
TD1
@nicholsonc_electric @Agrizz thank you to hear about your experiences. On par with mine. Exp Builder is worse than WAB. Definitely way slower for users, and doesn't help with user adoption.
ESRI Support told me to reduce the amount of layers in my map. First off why when WAB works, and secondly i only have about 20 layers in there and it still performs poorly.
Keep posting your experiences so ESRI development teams hear us and make a change. This software is too expensive to accept poor experiences.
MikeVolz
Does anyone using Experience Builder added many embedded images into their apps?  I ask because an Experience app was created at my org with many embedded images and the Experience hit the 1,000 resource limit making the app unusable as resources cannot be deleted from being referenced by Experience Builder even though the embedded images were deleted.
Using the below URL for monitoring resources in the Experience
https://support.esri.com/en-us/knowledge-base/problem-unable-to-add-resources-to-an-arcgis-online-it...
AllenZhang
Hi @MikeVolz . Did you delete the images in the image selector? Because unselecting images for widgets won't delete them automatically.
After delete them, save the app and refresh. The image resources should be cleared.
TD1
@Jianxia Experience builder still has the same performance issues and they seem to be getting worse. When is this going to be resolved? Provide a clear and concrete timeline as my users are frustrated and have abandoned using Experience Builder all together.
