Points drawn using the Draw Widget do not show up when printing
1602
11-13-2024 10:14 AM
WorcesterGTSS
I was testing out the new Add Text functionality in the Experience Builder Draw Widget (which seems to be working great!) and noticed an issue with the Draw a Point option. If I print my map using the Print widget in the app, the points I drew don't show. This doesn't seem to be a problem with any of the other shapes or the next text option, just the points.
Screen capture of shapes and text add to map using the Draw widget:
But when I print using the Print widget, the point features are missing:
ShengdiZhang
Hi @WorcesterGTSS ,
This bug is included in today's update. Please try it out when you have time.
Shengdi
Stephanie_F
Hello @WorcesterGTSS Esri Technical Support has this documented as BUG-000172235. Thank you for reporting it here!
ShengdiZhang
Hi @WorcesterGTSS ,
Shengdi
WorcesterGTSS
It's working fine now - thank you!
Samara
