Open existing survey dynamically within Experience Builder
649
11-14-2024 09:13 PM
bbywaterbw
I have an arcade script in my web map that allows me to click on a feature and in the pop-up window do a search for a nearby existing survey point and through some url passing of the global ID and some other fields, allows me to open an existing survey in a new window and populate some desired fields. This all works very well but I am trying to streamline the workflow for my colleagues and have the map in an Experience Builder and trigger either an embed widget or the survey123 widget open the desired survey. The idea is to have everything bundled in 1 app without the user having to jump between 2 or more apps. I've done some extensive searching and have not found a satisfactory solution for this. Is this even possible?
