I'm working with ArcGIS Enterprise 11.3 and ArcGIS Pipeline Referencing. I want to use the Location Referencing widget on ArcGIS Experience Builder, but it only works with the Search by Route widget. I have tried the LRS Identify, Add Point Event, Add Line Event, Merge Event, and Split Event widgets, but they do not work. I have a problem when selecting a route; it highlights the selected route on the map but does not add it to the field blank.
For example, in the LRS Identify widget, I can select a route, but there is no data shown in the window.
This is how I set the widget. Am I wrong?
And This is when I try to use it.
Do you have an answer because I have the same problem?
Did you ever find a solution to this? I'm having this same issue as well in 2025.
i have the same problem
