Location referencing widget can't add route
1511
10-10-2024 06:36 PM
April_J
Hello,
I'm working with ArcGIS Enterprise 11.3 and ArcGIS Pipeline Referencing. I want to use the Location Referencing widget on ArcGIS Experience Builder, but it only works with the Search by Route widget. I have tried the LRS Identify, Add Point Event, Add Line Event, Merge Event, and Split Event widgets, but they do not work. I have a problem when selecting a route; it highlights the selected route on the map but does not add it to the field blank.
For example, in the LRS Identify widget, I can select a route, but there is no data shown in the window.
This is how I set the widget. Am I wrong?
And This is when I try to use it.
(view in My Videos)
johnpol
Do you have an answer because I have the same problem?
AlisonWieckowicz
Same here.
Caitlin_Todd_LCOR
Did you ever find a solution to this? I'm having this same issue as well in 2025.
mazlianamohd_nordin
i have the same problem
