Good Afternoon,
I was curious if anyone in the community has already developed Layer List coder where when a user turns on a sublayer and the parent layer is also turned on similar to what you could do in Web App Builder?
You should post this to ArcGIS Experience Builder Ideas.
Hi, I used a library called ant design https://ant.design/components/tree-select#tree-select-demo-checkable.
They have different tree options, the checkable one is what you might be looking for.
Thanks everyone. I will post to the Ideas Page while I code it in the backend. Seems like a simple UI need for application users.
