Jimu-UI Modal doesn't allow scrolling of contents
429
03-26-2025 05:33 PM
NHannig
Trying to add a Modal with a large amount of content. When opening the Modal the content goes of the screen and I am unable to scroll to view the content off the screen.
This issue can be tested and confirmed in the Jimu-UI Storybook.
https://developers.arcgis.com/experience-builder/storybook/?path=/docs/components-jimu-ui-index-moda...
The scrollable property also does not work.
I think the issue is that the needed CSS related to Modal scrolling is not being added into the HTML document.
This issue also impacts Experience Builder.
KenBuja
MVP Esteemed Contributor
I use a modal window in my widget and it is scrollable. The window uses a component from a third-party library to build this editable table and uses a CSS file to provide its styling.
This is the code in the tsx file
  return (
    <Modal
      isOpen={modalVisible}
      //className="bg-default w-75 d-flex justify-content-between"
      className="bg-default w-100 d-flex "
      <ModalHeader closeIcon={<CloseOutlined />} toggle={toggleModal}>
        {title}
      </ModalHeader>
      <ModalBody className="w-100">
        <article className="table-container">
          <table>
            <thead>
// etc...
and this is the css file with the overflow property
.table-container {
  display: flex;
  justify-content: center;
  height: 500px;
  overflow: scroll;
 resulting in this table with the scrollable content
NHannig
Thanks for your reply. I found adding the following css to my local css file solved the issue. But the ExB/JimuUi team will need to fix their CSS.
.modal {
  overflow-y: auto;
.modal-open .modal {
  overflow-y: auto;
.modal-dialog-scrollable {
  height: calc(100% - 3.5rem);
.modal-dialog-scrollable .modal-content {
  max-height: 100%;
  overflow: hidden;
.modal-dialog-scrollable .modal-body {
  overflow-y: auto;
KenBuja
If my response answered your question, please click the "Accept as Solution" button
Also, try using the CSS utility classes with Bootstrap's Overflow
className="overflow-auto"
Kathleen44
This worked for me, thank you for sharing!
