Experience Builder Edit App Data Not Syncing
627
06-12-2025 08:17 AM
AGCknightchrism
I have a 123survey input I use in a web map that's been added as a widget in experience builder. I then add the edit app and connect the Map widget under layer configuration I select the 123 Survey input and have all the capabilities turned on.
Problem.
I then updated rows to reflect changes in a field in ArcGIS Pro. I added the feature layer (hosted) turned on edits made the changes and saved. I check the feature layer on the portal and the web map I made out of it and the table is saved with the changes.
When I go into the experience builder edit app. I want to make updates in the field but the old values I changed are still present.
For examples I have a bunch of rows under a field labeled black. I changed it to red in ArcGIS Pro saved it. I go to the edit app and the drop down still shows black and not the red updates.
Any ideas on how to get the edit app to sync my changes I made in ArcGIS Pro?
TianWen
Could you please share a sample app or a screen recording to help illustrate the issue more clearly? That would greatly assist us in further investigating it. Thank you!
