Issues in Filter and Query Widgets in Experience Builder
2138
11-19-2024 08:52 AM
CathyNiu_TPS
Hello,
We have noticed some bugs in the Filter and Query widgets following the November 2024 update.
App link for reference: TPS Crime App YTD
Issues:
1) The options displayed in the Filter widget are incomplete.
- Navigate to the app link > Filter > Turn off “Yesterday.”
- You will see data appearing across the city in every division, but in the Division filter, only 2-3 options are displayed instead of the full list.
- This issue is consistent across all filters within the Filter section.
2) Similar behavior is observed in the Query section, where the available options within each filter are incomplete.
Could you please assist in identifying and resolving this issue? Several users have reported these issues to us.
Thank you very much!
@Jianxia
@TianWen
Jianxia
@CathyNiu_TPS , thanks for letting us know. We are looking into it.
CathyNiu_TPS
Thank you! @Jianxia
Ke_Xu
by Esri Regular Contributor
Hi @CathyNiu_TPS,
Thank you for reporting the issue. We've released a patch for online and it should be working now.
Ke
CathyNiu_TPS
Thank you for the update and the patch! @Ke_Xu
JoelRogers
@Ke_Xu Can you confirm that this was fixed? I am still seeing the same behavior in the filter widget. I can create a filter in Dashboards that works. It can see all the possible values in a field. But, when adding a filter to Experience Builder some of the values are missing.
