Is there a way to load "Predefines Unique Values"
711
01-10-2025 06:47 AM
SanchezNuñez
Good morning,
Is there a way to load "Predefines Unique Values". I am currently entering them manually.
Thanks
DanielFox1
Hi @SanchezNuñez
Can you be more specific on the widget you are trying to use?
I have included a link to another community post which you might find helpful
Solved: Query widget - unique values - Esri Community
SanchezNuñez
Sure @DanielFox1 ,
in a Select, Query  or Filter widget when configuring the selection  with the button SQL Expression,  it opens a window called "SQL Expression Builder", then there is a way to Predefine Unique Values for a field.  I have to enter them manually. I am looking for a way to upload them, because I use this same search values in other widgets.
Ke_Xu
by Esri Regular Contributor
Hi @SanchezNuñez
Thank you for pointing this out. ExB does not currently support this feature. We will look into this feature further to see if it can be enhanced.
Ke
SanchezNuñez
Excellent @Ke_Xu !!
