Image Widget that accepts .SVG files?
3122
03-28-2022 10:28 PM
FredericPoliart_EsriAU
I would like t know if there is a method or a widget to display Images that would accept .SVG format?
At the moment (as far as I know), the default ExB Image Widget only accepts ONG, BMP, JPEG formats.
Has anyone done an image widget for SVG files?
TonghuiMing
@FredericPoliart_EsriAU,
Due to the security facts (XSS vulnerability & lack of sanitization for SVGs), we have removed the support for SVG (& SVGZ) files since AGO 8.4/Enterprise 10.9/Dev 1.3. Thus, there is no way you could use the OOTB ExB functions with SVG uploads now.
TonghuiMing
OK so in theory, I could create my own SVGImage Widget by
1. Cloning your \client\dist\widgets\common\image\
2. adding a new setting called "svg_data"
.. or is it easier to just upload the .svg somewhere public , and use the <embed> widget 🙂
jcarlson
The Embed widget allows you to embed by Code, not just by URL. Simply paste your <svg>...</svg> code there.
- Josh Carlson
Kendall County GIS
