How to get Near Me working faster
1021
01-10-2024 05:54 AM
BrandonPrice1
Hello,
Is there anything that also can be done to get my Near Me working faster for this app: https://experience.arcgis.com/experience/4b60526db54748a3be0ef0f89e404137?
Try searching for parcel 4462032013 under the Risks/Habitats search to test it. The parcel field being queried in the near me has 100 fields (only 9 displayed in the popup). Could that be a factor?
-Brandon
AzizaParveen1
Hi @BrandonPrice1 , number of fields may be contributing in the slow performance, do you need all these fields? If not I would suggest that you delete unnecessary fields, but if you need them, you can add attribute index that might be helpful, here is a link for how to do it with ArcGIS Online hosted services https://community.esri.com/t5/arcgis-online-questions/arcgis-online-feature-service-attribute-indexe....
Another setback we have right now is Experience builder uses server side query at this moment, so it is bit slower, but the good news is, they are working on implementing client side query and you will get much better performance once this work is completed and released
AzizaParveen1
In my last response, the link I shared is a bit old for creating attribute index. Here is the updated doc on how to create attribute index in hosted feature layer. you need to be the owner of the layer or you need administrator role in your org.
https://doc.arcgis.com/en/arcgis-online/manage-data/manage-hosted-feature-layers.htm#ESRI_SECTION1_0...
BrandonPrice1
Thanks Aziza. I will consult with the administrator of this data. The parcel layer was published using a database view layer so I don't know if there will be limitations with adding the attribute index.
