How to close fixed window (splash screen) from a custom widget
4234
6
08-30-2021 05:51 AM
LuisAntonioRodriguezGonzalez
I've developed a Experience Builder Widget, that has a "Iniciar sesión" button. I've added this Widget in a fixed window (splash screen) and when I click in the "Iniciar sesión"  button, I want to close the window.
 Regards,
Tags (1)
by Anonymous User
Not applicable
If this fixed window is actually a page, see the code/button I posted here:
https://community.esri.com/t5/arcgis-experience-builder-questions/how-to-open-a-specific-page-with-a...
You wouldn't actually "close" anything. You just have the button call the other page.
Boyang_Wang
If your main page is called Page 1, just do the following:
1. Click on the button in the edit mode
2. Select "Set link" in the right column
3. Set link to Page, Page 1, App window, like this:
Thanks, but this solution is not suitable for me, because I,ve developed a custom buttom in my custom widget.
The custom buttom has to do some actions before close the splash screen.
by Anonymous User
Not applicable
This is my code based on the KevinHibma answer:
export default function Widget(props: AllWidgetProps<IMConfig> & ExtraProps) {
  let linkCloseRef: HTMLButtonElement;
  const getLinkComponent = () => {
    let linkTo: LinkTo;
    linkTo = {
        linkType: LinkType.Page,
        value: "current_page"
    } as LinkResult;
    let queryObject = props.queryObject;
    return (
      <Link ref={ref => (linkCloseRef = ref)} to={linkTo} target="_self" queryObject={queryObject}
        className="linkClose"
      </Link>
  const onIniciarSesion = e => {
    const usuario = getUsuario();
    const password = getPassword();
    if (usuario === null || usuario === '' || password === null || password === '') {
      setMensajes(`${getI18nMessage('introducirUsuarioPassword')}`);
    else {
      const url = `${props.config.wsl}/Login.ashx`;
      esriRequest(url, {
          query: {
            u: usuario,
            p: password
          responseType: "json"
      }).then(response => {
        let geoJson = response.data;
        if (response.data.cr === 1) {
          if (response.data.np === 1) {
          else {
          linkCloseRef.click();
        else {
          setMensajes(`${getI18nMessage('errorUsuarioPassword')}`);
      }).catch((error) => {
          console.error(error);
  const LinkComponent = getLinkComponent();
  return (
      <div className="jimu-widget-acceso-filtrado">
        {LinkComponent}
        <div className="overlay"></div>
        <div className="envelope buried">
        <div className="contenedor">
          <table className="acceso-filtrado-table" cellSpacing={5}>
          <tbody>
            <td colSpan={2}>
              <div className="acceso-filtrado-btn" onClick={onIniciarSesion}>
                <FormattedMessage id="iniciarSesion" defaultMessage={defaultI18nMessages.iniciarSesion}></FormattedMessage>
              </div>
            </td>
            </tr>
          </tbody>
          </table>
        </div>
        </div>
      </div>
DaveFullerton
@LuisAntonioRodriguezGonzalez are you using your custom widget in a fixed window that is set as the splash screen?  Or is it as @Anonymous User was referring to that the splash screen is actually a page?  I am having trouble getting my custom widget to close the fixed window but only when it is set as the splash screen.
Hi @DaveFullerton the splash screen is actually a page.
