How to change default docked popup location in Experience Builder
14138
21
03-14-2021 08:33 PM
AndyHodren1
Experience Builder Version: 1.2 (running on ArcGIS Enterprise)
Is it possible to change the default location for docked popups in experience builder?  The experience I am building defaults to the top-right of the screen which obstructs other tools.
Undocked:
Docked:
ZachBodenner
MVP Regular Contributor
Hi David, I'm trying to follow along with your suggestion but running into issues viewing the new widget in the ExB. I copied the map widget and pasted it into client/your-extensions/widgets, added code sample above:
changed the name of the widget in the manifest.json to Map2, and then attempted to run the compiler as described in step 5 of this documentation. However, I get an error in the command prompt:
C:\Program Files\ArcGIS\ArcGISExperienceBuilder\client>npm run build:prod
> exb-client@1.11.0 build:prod
> cross-env NODE_ENV=production OUTPUT_FOLDER=./dist-prod webpack --mode production
'cross-env' is not recognized as an internal or external command,
operable program or batch file.
Am I missing a step? I don't have a lot of experience with customizing or creating new widgets.
Happy mapping,
- Zach
JeffreyThompson2
MVP Frequent Contributor
Make sure that the name in manifest.json matches the name of the folder it's in.
GIS Developer
City of Arlington, Texas
Yuriko
I was able to modify my copy of the 'arcgis-map' widget to dock the popup by default by updating the 'onJimuMapViewCreated' function in v1.13. To change the location of the docked popup update the "position" attribute.
onJimuMapViewCreated = (jimuMapView: JimuMapView) => {
    jimuMapView.setMapWidgetState(this.props.state)
    this.setShowPopupUponSelectionForJimuMapView(jimuMapView)
    // START CUSTOM CODE
    console.log('onJimuMapViewCreated function loaded')
    if (jimuMapView.view && jimuMapView.view.popup) {
      // Modify the popup property to dock the popup by default
      jimuMapView.view.popup.dockEnabled = true;
      jimuMapView.view.popup.dockOptions = {
        breakpoint: false,
        position: "top-right"
    } else {
      console.error('MapView or Popup is not initialized');
    // END CUSTOM CODE
ZachBodenner
Kinda like this?
That doesn't seem to have made a difference.
Happy mapping,
- Zach
JeffreyThompson2
Are you trying to do a server installation? You are connected to the C drive.
If you are trying to set up a local installation on your desktop, you should be following these directions. https://developers.arcgis.com/experience-builder/guide/install-guide/
GIS Developer
ArcGIS Experience Builder enables you to create web apps and pages without coding. This video introduces ArcGIS Experience Builder and how you can maximize its wide array of capabilities. Learn more: http://ow.ly/CK8R50FUTaP ...
ZachBodenner
Ah well I've already done the installation, this particular one with the assistance of an ESRi tech to get the Experience Builder running as a Windows Service as opposed to starting it up from the command prompt. Our installation experience revealed that we couldn't run ExB as a service if it was installed on a Network location, only on a machine's C drive, so there it lives. All I'm looking to do now is add the new widget.
Happy mapping,
- Zach
Jianxia
Configuring where to dock the pop up from 6 positions is planned for the upcoming June release of ArcGIS Online.
Bryan_krg
The ability to dock the popup is great. It's now under Map -> Content configuration. But what would also be good is the ability to add the popup to a sidebar like in the picture below. (and stop the popup displaying). The Feature Info window is close put not the same.
Jianxia
@Bryan_krg , could you please elaborate a bit more on Feature Info not working in the way you want in a side panel?
ZachBodenner
I'd like to agree with @Bryan_krg on this one: the feature info widget is not the same, primarily in how it reads Arcade. I spoke with some of the ExB Team at the UC this year about it (still haven't gotten back to me) and they said they would investigate and probably log a bug. It would be nice to have even more auto-docking options, but this is a good feature added, thank you @Jianxia !
Happy mapping,
- Zach
