How to adjust a popup window to see all attributes
307
12-04-2025 04:31 AM
SanchezNuñez
Good morning,
Is there a way to configure a popup window to display all  fields, in this case six fields? Currently, it only shows the first three, See Attached image.ExpericenBulderPopupWindow.png
Laura
by MVP Regular Contributor
JasonBOCQUET
I recommend you to use the feature info widget in a controller widget and set an action on your map widget that opening the widget as a popup instead of the original popup when you click on a feature. Just think to unactive the popup in map widget.
By this you can set the size of your popup like you want.
MappyIan
I second what @JasonBOCQUET said.  Use the Feature Information widget then you have control over the size and placement.
