How Can I Avoid the OAuth Permission Popup in ArcGIS Experience Builder?
2128
06-24-2025 06:48 AM
Labels (2)
SantoshV
Hi everyone,
I've built a WebGIS application using ArcGIS Experience Builder and implemented OAuth 2.0 for user authentication. Every time a user logs in, they are prompted with a permission popup asking to allow access to their ArcGIS Online (or Enterprise) account.
Is there a way to suppress or avoid this popup for a smoother user experience?
Here are some details about my setup:
  • The app is registered in the ArcGIS portal with a valid redirect URI.
  • I'm using user-based OAuth (authorization code grant).
  • The app accesses secured content (not public).
  • The domain is added to the portal's trusted servers list.
I’m open to suggestions like using App Login, adjusting scopes, or any best practices others have used to streamline the login process.
Thanks in advance!
ZachBodenner
MVP Regular Contributor
Yeah there's a way! First, go into the app you have registered in your Portal/AGOL and find the AppID:
Then, after you download the app data and have hosted it on your server, open the app's cdn folder and find the config.json:
From there, search for 'ClientID' and add the app ID into that parameter
Happy mapping,
- Zach
WilsonLee
Hi, I have the same issue and would like to get rid of the "sign in popup". I tried Zach's method above, but it didn’t work. Do you have any other ideas?
Wei_Ying
Hi @SantoshV since 1.18 and June 2025 Online release, you have the option "Skip sign-in prompt for security resources". By enabling it you can skip the auto sign-in prompt for unshared resources.
