highlight popup
1782
12-11-2024 03:55 AM
TimDemuynk
Hello,
In my webmap it is configured that the "water layer" contains a popup.
In experience builder, the map is configured that popups in general are possible
The problem is, when I click on a water polygon, the area gets highlighted, and then if I click on that highlight, I get this popup (image below), which makes no sense in my opinion.
Is this popup highlight something configurable? I just don't want to see this highlight popup.
Thank you
Tim
RhettZufelt
MVP Notable Contributor
Is it possible that it is giving you the popup for another layer (water - hightlight), or is this the title you put in the water layer popup config?
What does it show you if you click on the arrow in upper right to show you 2 of 2?
R_
Ke_Xu
by Esri Regular Contributor
Hi @TimDemuynk,
This issue has been fixed on November 2024 ArcGIS Online. And will be fixed on Portal 11.5.
Ke
AndreLoerch
@Ke_Xu Thank you for letting us know about this being fixed in the 11/2024 AGOL and Enterprise 11.5 versions of ExB. Do you know what version of ExB Developer this will be fixed in? The issue exists in ExB Developer 1.15 (what we're currently using).
AndreLoerch
I just realized that 1) There's a new version of ExB Dev from the beginning of December, 1.16 and 2) It does seem to have solved this issue.
KarenHall
I'm having this same issue as the original post. Is there a workaround?
