Hide time in Table widget
18609
37
02-16-2022 09:47 AM
AmyRoust
I'm using the Table widget in Experience Builder (the online version, not developer edition). My date fields are displaying the time, and I'm wondering if there is a way to hide that? Time is irrelevant for this dataset - they just need to track the date.
Tags (3)
TonghuiMing
@BrittanyBurson - The timeline does not have anything to do with popup settings, it is specifically related to temporal settings inside your Map Viewer - two different things.
However, the behavior you mentioned is somehow valid and we will take a look to evaluate if there is any room for enhancement. In the meantime, I suggest you go with Esri Support or create another separate post for the sake of tracking. Thanks.
NicholeSalinger
Hello @TonghuiMing Do you have a resolution on this issue? I'm in the process of republishing my map from WebAppBuilder to ExperienceBuilder and this feels like a pretty simple fix on ESRI's part considering that this is now a 4 year old issue. Please advise. Thank you!
Shen_Zhang
@NicholeSalinger, the table widget now supports Map Viewer date and number formatting (effective October 2025 for ArcGIS Online). These settings persist automatically within the widget.
If you're using ArcGIS Enterprise, this feature will be included in 12.1.
Shen Zhang
TonghuiMing
@BrittanyBurson
The new option "Display accuracy" added in the recent AGOL release can allow you to define the level of info you'd like to display now:
Tiff
Hello @TonghuiMing where do you find this setting? I do not have a slider, I just have a table I would like to remove the time from, and display just the date.
TonghuiMing
The Table setting needs to be handled by the Table widget, it uses the API widget so I believe there are some complications. The ENH I mentioned above is only for the Timeline widget.
JulioGarrido
OK...  Here we are almost two years after this discussion started and ESRI has not resolved what seems to be a simple issue.  The simple solutions are to either honor the map layers settings or have a checkbox/slider disabling the time from showing.  Not only is it affecting the tables, but also the edit function.  So frustrating sometimes.
Tiff
Hi @JulioGarrido, I agree. I have many layers with date fields that only need the date in the table and the time cannot be removed. Esri released new ArcGIS Online date types for Date, Time only, etc. but it is so new (AND requires you to create totally new fields) that I would rather have a solution in Experience Builder and Instant Apps to honor map layer settings.
Sidenote, you may be able to bypass the editor issue by configuring the Smart Forms in Map Viewer for date only. However, that only works for editing and does not resolve the Table issue.
JulioGarrido
Hi Tiff,
I created the form using Field Maps and disabled the time.  However, ExB still shows the time in the editor as well.
Earlier today, I talked with ESRI Support and they see it is an issue.  Especially after they saw the date/time in the form and the map were both set to DATE.  Hopefully, they can find something, or report it as a bug so it can be fixed.
Tiff
Great, thanks for the update @JulioGarrido. I am not currently able to submit anything to esri support so appreciate that you did. Hopefully that can be resolved soon to only include dates in the table.
