GolbalId parameter cannot be accessed - Survey123 in Experience Builder
2327
11-05-2023 02:12 PM
MelP
Hi All,
I have created an experience using the survey widget. The user selects a record from the list widget which opens the existing survey record to edit.
This works fine for users with admin roles however returns an error for Creator Data Editors.
I have followed trouble shooting here but am still unable to resolve. Has anyone else come across this issue?
The Survey, Feature layer and experience builder application are all set to Organization level sharing.
MelP
Hi @gis_KIWI4 ,
I had the survey widget set up just as you have explained, checked survey layer had globalid (i knew this couldn't be the issue as editing the survey records worked fine for admin users).
I ended up creating a new survey (exactly the same as the the other) and it worked!!
No idea what the issue was but i suspect it may have had something to do with configuring permissions through the survey feature layer and re-publishing the survey a number of times which caused unexpected behavior. Noted here
Happy to say the issue is resolved!
Mel
ZhifangWang
Hi @MelP ,
The knowledge base article you referenced is the correct one to generally solve this error.
Can you please confirm that "Creator Data Editors" see the red error message for all survey records (including ones submitted by themselves) or only records that submitted by other users?
  1. If all records raise the same error, it means the feature layer (view) behind the survey is not shared appropriately.
  2. If only records submitted by others raise this error, it means detailed settings in the behind feature layer (view) is not correct.
In addition, can you please confirm if your survey was published from Survey123 Connect or the Survey123 website?
MelP
Hi @ZhifangWang ,
Thank you for your reply, i can confirm Creator Data Editors see the error message for all survey records. I am using the hosted feature layer (not a view - Do i need to be using a view?) and the settings are as in the screen shot below -
The Survey was published from the Survey123 website, share settings are as follows -
Any help on this would be much appreciated.
Mel
gis_KIWI4
MVP Regular Contributor
Hi @MelP
I tried publishing a survey and using the widget within a ExB app. It seems to work for me.
I think the issue might be in setting the up the survey123 Widget in ExB.
Could you confirm if that mode is set to - "Edit an existing record" and the source layer is set to the survey123 layer?
In my example I have 2 datasources on the map.
When I select the one that is not the survey layer then I get the error suggesting GlobalID was not provided.
When I select a feature from the survey123 layer I can successfully edit the feature.
If that's not it then you could try checking that the survey123 layer created has a GlobalID field in it. I don't see why it wouldn't but worth checking.
Hope this helps 🙂
MelP
Hi @gis_KIWI4 ,
Mel
