Get Other Widgets in ArcGIS Experience Builder setting UI
5142
12-27-2023 12:40 AM
bogind
I am creating a custom widget in ArcGIS experience builder and am trying to get a list of all the widgets currently defined for a page or for the entire app inside the setting UI.
I tried using the widget state to transfer the list, as well as create it in a similar way to the one used in the Control the Widget State example, but when I use the same code in setting.tsx I get the widgets that are used to create the settings UI sidebar, and not the current app/page widgets.
For example, when I run:
import { React, getAppStore } from 'jimu-core';
const { useState, useEffect } = React
let state = getAppStore().getState();
const [appWidgets, setAppWidgets] = useState({} as unknown)
const [widgetsArray, setWidgetsArray] = useState([] as any[])
// Update the appWidgets property once, on page load
useEffect(() => {
  const widgets = state.appConfig.widgets
  setAppWidgets(widgets)
}, [state])
// Update the widgetsArray and sidebarWidgetsArray properties every time appWidgets changes
useEffect(() => {
  if(appWidgets) {
	const widgetsArray = Object.values(appWidgets)
	setWidgetsArray(widgetsArray)
}, [appWidgets])
Then widgetsArray is supposed to contain all of the widgets in the app, which works if run inside widget.tsx, but in setting.tsx I get a list of the setting UI components.
I know the process should be possible, because the MapWidgetSelector component from 'jimu-ui/advanced/setting-components' uses it to grab just the map components, but its code isn't open and I can't find how it's taking the widgets defined for a page.
Is there an efficient way to get all of the widgets in a specific app/page into the settings UI?
bogind
I fount the solution by chance, in the message subscriber example.
It is possible to get the state and config of the internal app through:
import { getAppStore } from 'jimu-core';
// The app state
getAppStore().getState().appStateInBuilder
// The app config
getAppStore().getState().appStateInBuilder.appConfig
It is then possible to get all of the pages, layouts and widgets that are already defined in the app
const internalAppConfig = getAppStore().getState().appStateInBuilder.appConfig
const appWidgets = internalAppConfig .widgets
JeffreyThompson2
MVP Frequent Contributor
Did you know that Experience Builder actually uses two simultaneous React applications, one for the build mode and one for the page you are building? I think this is the core of your problem. What are you trying to accomplish?
If you want to see how a widget is configured, it's possible to open up the config.json file in your text editor and read the information directly.  Go to /server/public/apps/yourAppNumber/config.json to see the published version and /server/temp/yourAppNumber/cdn/yourVersionNumber/config.json to see the current working version.
GIS Developer
City of Arlington, Texas
bogind
I didn't know that, but it makes sense in a way, though I still don't understand how the instance for the build mode is getting the information about specifically the map widgets added.
What I want to create is a logger widget which will allow setting logs for actions for multiple widgets.
The idea being you could set an address for an API, set a call method (ie. GET/POST), and allow users to log specific events which will be preset for every widget or map tool.
I know that I can let users set everything for it through the config.json, but I wanted to allow selection of widgets through the widget settings UI.
JeffreyThompson2
https://community.esri.com/t5/experience-builder-custom-widgets/feature-panel-widget-1-7-1-9-8-22/ta...
You might be able to get some inspiration from looking at Robert Scheitlin's Feature Panel. Much of the code is dedicated to auto-detecting a sidebar widget.
GIS Developer
MichaelLev
@JeffreyThompson2 , you mentioned EXB uses 2 simultaneous React Apps. It seems I know almost nothing on how EXB (Developer Edition) works... I worked much on WAB and now I am preparing to start develop custom widgets for EXB. It will help me to "understand" how EXB code works...
Can you please elaborate, and also direct me to proper documentation?
bogind
// The app state
// The app config
