Frequently needing to clear browser cache - Experience Builder: Enterprise 11.5
4642
14
07-16-2025 09:10 AM
Andrew-Bowne
Anyone have to constantly clear your browser cache so that ExB apps display in both the builder and during runtime?
Specifically, I am seeing React errors in both Builder and when the app is running.  I don't have an example screenshot of Builder error(s) but here is one at runtime.  (apologies, it was sent from to me from a user who doesn't know how to use print screen 😂)
This happens in Chrome, FF and Edge and didn't happen until I upgraded to 11.5.
Thoughts?
CodyPatterson
MVP Regular Contributor
Hey @Andrew-Bowne
I recently upgraded from 11.2 to 11.3, and our Chrome and Edge users had quite a few problems with cached files, give this a shot here:
First, try in Chrome, press Control + Shift + Delete and follow the arrows:
Make sure it's set to Everything and the file cache, give it a reset and let me know if this ends up working, if not, could you provide a screenshot of the console and network panel on the developer window (f12).
Cody
Andrew-Bowne
Yup, did that.  I also went into dev tools-->application and cleared out all storage.  It still happens randomly.  Next time it happens (because it will happen), I will grab a screenshot and post it.
I would like to say it's isolated but I have had several reports of this behavior.  Clearing the cache works, but it seems to only be temporary.
Cory__Williams
I'm also seeing this issue as well! I have had users needing to clear cache multiple times and I have had React-130 errors numerous times and even having Layer Panels not appearing, just blank.
Andrew-Bowne
.."Layer Panels not appearing, just blank..."
You mean like this????  This just happened for me in the map viewer:
Dev Tools:
Then after clearing cache and hard reload, the layers "reappear":
JunshanLiu
This seems like a server-side issue, we are still confirming the root cause.
mwartman_grey
DavidColey
MVP Frequent Contributor
mwartman_grey
ZachBodenner
I've been having this issue specifically with services shared publicly. Specifically, I keep getting the prompt to enter credentials for our Enterprise Portal to access resources that have been shared with the public. It's not a huge deal for me to clear my browser cache to make the problem go away, but the average resident-map-user would not think to do this, and shouldn't have to. I just applied the Applications patch, so we'll see if the issue crops again - did anyone else experience something similar that was solved by applying the patch or through some other fix?
Happy mapping,
- Zach
