Find address or location with Search widget does does not allow to see other layers
673
06-09-2023 10:33 AM
JoseSanchez
Hello everyone,
When searching for an address with the Search widget, and clicking on the address to zoon to the location, layers from the Map List widget are frozen. If I turn then layer visibility on and off, it does not work. Even turning on the layer before doing the search, makes the layer invisible again after zooming in
To show the layer, I have to remove the address from the Search widget and then layers behave normally.
When doing the same search for the Search Tool from the Map widget it works fine.
Is this a bug?
