Filter widget for multiple tables
789
12-24-2024 06:24 AM
doronwen
Can a single filter widget sort more than one table at a time?
I know you can have multiple tables connected to a single filter, but in the widget itself you can add a SQL Expression only to individual tables.
Example: Table A, Table B and Table C all have different data, but they also have a common field named "Region". When a user select region 1 for example, I'd like all three table to be filtered on region 1.
Right now I have 3 filters - one for each table - and I can't find a way around it.
Tags (1)
Ke_Xu
by Esri Regular Contributor
Hi @doronwen,
You could create a Group filter. Add three tables and build SQL expressions based on the common filter "Region".
Ke
doronwen
Hi @Ke_Xu
Your solution does appears to be what I'm looking for, but I do not see this option in ExB and I'm on 11.1
What version of enterprise are you running?
Ke_Xu
Hi @doronwen,
Group filter was released on ArcGIS Online in February 2024 and ArcGIS Enterprise 11.3.
Ke
doronwen
OK, that's the reason I'm not seeing it. I think my organization is pretty far way from upgrading to 11.3.
Thanks @Ke_Xu
