Filter table from multiple widgets action
6739
14
07-26-2023 10:36 PM
Moi_Nccncc
I have two table widgets. When the user selects a value from Widget 1, it filters "Table A" on the map based on the selected Category. However, when the user selects a value from Widget 2, I want "Table A" to be filtered on the map based on the combined selection from both Widget 1 and Widget 2.
Here's the structure of "Table A":
ObjectID Category Zone
111
221
312
432
The filtering logic should work as follows:
  1. When the user selects a value from Widget 1, "Table A" should be filtered to show only rows where the Category matches the selected value.
  2. When the user selects a value from Widget 2, "Table A" should be filtered to show only rows where both the Category matches the selected value from Widget 1 and the Zone matches the selected value from Widget 2.
For example:
  • If the user selects Category 1 from Widget 1, the table should be filtered to show rows with ObjectID 1 and 3.
  • If the user then selects Zone 1 from Widget 2 (while Category 1 is still selected in Widget 1), the table should be further filtered to show only the row with ObjectID 1.
How can I implement the filtering based on both widgets' selections effectively?
ChristopherCounsell
MVP Frequent Contributor
@DanJiang the user is on Portal for ArcGIS 10.9.1. It was released in Nov 2021. This is equivalent to Experience Builder 1.5. The current release of ArcGIS Online is on Experience Builder 1.12.
https://developers.arcgis.com/experience-builder/guide/release-versions/
There's a good chance that the builder has changed significantly over the 7 updates to Experience Builder and the underlying JS API.
I can't see anything specific in the release notes to confirm if it will/won't work for the user's environment, but it's probably worthwhile to test in an equivalent environment.
https://developers.arcgis.com/experience-builder/guide/whats-new/
DanJiang
Yes, there could be bug fixes among those releases.
Moi_Nccncc
cannot access your sample (Public Account user cannot access this application.) 😞
Moi_Nccncc
I have public account so I am not able to access you sample.
DanJiang
@Moi_Nccncc sorry about that. I've shared the app public, please try again.
