Filter - just one filter simultaneously
2825
02-21-2022 10:59 PM
KalleSchmitz
Hello everyone,
I have created an application in the Experience Builder and defined four different filters that can be selected via the filter widget.
However, I can't manage that only one filter is active at a time, or that when you click on another filter, the previous one is switched off.
If two filters are active at the same time, they do not work...
Can you help me?
Tags (1)
RhettZufelt
MVP Notable Contributor
If using one Filter Widget with multiple filters in it, you need to make sure you have the AND/OR set properly if you want more than one filter to work on the dataset.
If you want it to show both values, you need to use "OR".
R_
KalleSchmitz
Thank you for the answer!
However, I would like to set it so that the previously selected filter is switched off when you select a new one...
DaveFullerton
I have posted an Idea for this.  Please vote it up.  If you could also post a comment under the Idea that explains your use case that would add even more weight:
https://community.esri.com/t5/arcgis-experience-builder-ideas/filter-widget-option-to-allow-only-one...
JonathanPollack
Yes, I think this is a bug.  If you use "OR" like you should the ACTIONS (zoom or pan) do not work (should zoom to extent of both but doesn't).
