Feature report attachment size
524
07-14-2025 12:13 AM
TjeerdBruijn
Hello,
I have a question about the feature report function in the Experience Builder.
I want to use the feature report for a feature layer, and not the survey.
When i use the attachment syntax, i can't find out how to set a maximum size for the photo's. for 1 photo i can do it, but when i want to iterate the attachtments, it doesn't work.
Does any one know how to fix this?
This is the syntax what i found from the help
${#$attachment | attachmentsDefExp:"CONTENT_TYPE like '%image%'"} ${$file} ${/}
And second question; Is it possible to place the images side by side instead of stacking them vertically?
Thank you very much
Ruth_JiatengXu
Hi @TjeerdBruijn ,
Thanks for sharing here! You could use ${#$attachment}${$file| size:300:0 }${/} to set the maximum width of the images.
If you need the images side by side, please ensure there is no line break after ${$file| size:300:0 } in your template.
Ruth
