Export button does not appear in Experience Builder widgets with ArcGIS Enterprise 11.5
8761
13
06-27-2025 08:48 AM
AldoBertone
Hello!
My organization upgraded ArcGIS Enterprise from 11.3 to 11.5, and I am the Enterprise administrator.
Within Experience Builder (ExB), a lot of widgets (Select, Table, etc.) allow to export data as csv file, and the export options are configured on the "Data pannel" of ExB. So far so good.
From 11.5 Enterprise's version, I encountered problems with the export button (e.g., export to csv) within ExB widgets (Select, Table, etc.). In detail, using ExB app, web map and web services (e.g., map image layer) with a member that is not the owner, the export button on ExB only appear if particular Member rules are configured. I tried two different member with different Member rules, one without "Administrative privileges" flags, and another with some “Administrative privileges" flagged. Member with "Administrative privileges" has the button to download data on ExB, while member without "Administrative privileges" not! When at least one "Administrative privileges" of Member rule is flagged, export button appear on ExB widget, otherwise no button appear. Furthermore, the export button always appear for member who owns the ExB, web map and map image service. Attached configuration of Member Rules and export button behavior on ExB widget.
This happen on two different Enterprise systems. On the previous version of Enterprise the export button was not dependent on the Member Rules.
Here my question: is this behavior normal? is there the possibility to enable the export button for member without "Administrative privileges" in Member rules? It is quite strange, because only Creator user type can use the export button on ExB.
Thank you for your support
Aldo Bertone, Italy
AnnaFriedl
I am observing the same issue as AldoBertone described. In an Experience in AGE 11.5 the Export Option in a table widget is not available for users without administrative priviliges. The "Allow others to export to different formats" option in the item settings is enabled for all feature layers.
Are there any updates on this issues yet? I don´t see that BUG-000177589 or BUG-000177605 are covering this issues.
Best regards,
Anna
YueyangLi
Hi @AnnaFriedl ,
BUG-000177605 should address the original issue — all map services being allowed to export. However, the fix is not included in 11.5; it will be available in 2025R02 and the next AGE release.
Best,
Yueyang
AnnaFriedl
Hi Yueyang,
thank you for your reply.
I also contacted the Esri Support and it turned out, that the problem I encountred, is due to BUG-000177378 - In ArcGIS Experience Builder, non-administrative users cannot export map image layers published to ArcGIS Enterprise 11.5.
Best regards
Anna
TravisSlack
For the record, using a feature service also did not work for me as per the recommendation without using the export flag during publish. I had to republish the feature service with the "Export data" flag which was not required prior to upgrading server to 11.5
