Query Widget URL Parameters
343
03-09-2026 03:43 AM
RodWoodford
Hi, Is it possible to build a URL Parameter using the Query Widget? I would like to build a URL parameter that will display results from a selected query with the map zooming to. I have a query with 3 dropdown lists for users to select from with the result being returned and the map zooming to. How would I build the URL parameter that contains a parameter for a dropdown selection from one to the 3 dropdown lists with the result returning and the map zooming to that selection. This is possible using WABD. Any advice would be great.
cheers
Rod
