Experience Builder Third Party Integration
4037
6
11-23-2023 07:13 AM
GB7
We have some Informatica, TIBCO Rest APIs in our Organization.
is it possible hit a 3rd party API from Experience Builder Out of Box? Does Experience Builder out of box allow 3rd Party integrations? Like EAI, informatica services etc. Donot want any customization.
I did search online but found nothing much. Most of them recommended downloading Experience Builder Developer edition and customizing it.
JeffSilberberg
Can you use a velocity feed and then incorporate the output into the Experience Builder Application -
GB7
Thanks , would ArcGIS Velocity be able to take incoming and outgoing API calls? i.e. calls made to ArcGIS environment from Third party API and calls made to Third party API from ArcGIS environment
JeffSilberberg
@GB7
   Velocity can receive Posts and Poll a 3rd party site based on timed intervals.  As well as Post back from an output HTTP Node.
    You should be able to make calls to a 3rd Party API from within ArcGIS using Arcade, depending on the complexity of the API being invoked.
GB7
Thanks I will try this out
FredericPoliart_EsriAU
Geovonic Connect [link] (ArcGIS MarkePlace) enables you to bring information from your 3rd party software inside your ArcGIS. This simple but clever Experience Builder widget is designed not only to bridge workflow gaps but to drive efficiencies.
We use it with many clients (utilities/city councils, etc).
Enable users to select features on a map and view associated third-party information, retrieved in real-time via the Geovonic Connect widget.
A range of retriever and connector plug-ins are available for purchase and custom plug-ins can be developed on request. Existing plugins provide real-time integration with Salesforce, Sharepoint, Civica, TechnologyOne, relational databases, AWS, weather services, Google and file-based data sources.
Installing "Geovonic Relay Service" on your internal network allows for easy and safe connection to the Geovonic Servers,  holding the "link matching query" between one system and the other.
https://www.esri.com/en-us/arcgis-marketplace/listing/products/39748c5a468349828dbfed06f0677889#:~:t....
FredericPoliart_EsriAU_0-1712096804897.pngFredericPoliart_EsriAU_1-1712096823361.pngFredericPoliart_EsriAU_2-1712096841542.png
JoClarkeBega
Fred - we are implementing Geovonic connect here, and while the Civica Authority connectors are certainly easy to configure,  I am finding the range of Authority Altitude data connections very limited. Owners but no contact details for them, nothing for Water Meters/Accounts, Charges or Property attributes or Registers. Are these likely in future or do we need to make use of APIs for these? Thanks Jo
