Experience Builder Pop-Up
441
02-10-2026 09:46 AM
EmilyTrant
I have a large zoning layer in Experience Builder where the pop-up only seems to work if I've stayed in the same extent for 20+ seconds to let the layer draw completely. Is there a way to fix this? This feature layer was uploaded in state plane if that matters. I could project it to WGS 84 WMAS and upload it if this would help. TIA!
RyanUthoff
MVP Regular Contributor
So if you click a feature to open the pop-up, the pop-up doesn't open until after the layer finishes drawing? If so, then that sounds like normal behavior to me (at least it is in my experience with ExB). I think what it will come down to is improving the performance of your zoning layer.
I'm assuming your ExB app and data is all hosted in AGOL? If that's the case, you can try configuring some of the settings on the hosted feature layer (such as the spatial index and optimize layer drawing). This blog post has a lot of good information.
I don't think it would hurt to reproject the data to Web Mercator. The data essentially gets reprojected on the fly anyway when accessing it through the web map. So theoretically, it will take less processing power to display the data. But in practice, that usually happens pretty fast.
EmilyTrant
Thank you for your response! I tried and no luck really. This feature layer has over 50 unique values for symbology and over 110,000 values/parcels...
