Experience Builder Organization Theme doesn't match Shared Theme
4721
9
11-20-2024 11:23 AM
Labels (2)
MatthewProctor-Brown
I'm trying to use Shared Theme to apply our org's Brand Guideline colors to all of our apps.
For older apps the Shared Theme controls are working as expected: I can directly set the header colors, buttons, and body text.  It doesn't really fit our palette well, but I can use the grayscale colors fine.
For Experience Builder, the "Organization Theme" doesn't match any of this, instead defaulting to a different mid-grey for Header Color and completely ignoring the Shared Theme Logo.
If I go through and customize a Theme, it has an entirely different set of named colors than Shared Theme.
  • Primary
  • Secondary
  • Light
  • Dark
  • Success
  • Info
  • Warning
  • Danger
Setting these gives much better results, but seems like it must be done for each app individually.
Why is the Organization Theme creating such different colors?
Is there any way to configure a common theme that respects our brand colors?
2 Solutions
Wei_Ying
Hi @MatthewProctor-Brown Thanks for your feedback!
The shared theme in Org is different design system compared to Experience Builder.
Experience Builder theme is much more complex and has more color variables then shared theme does. So we can only try our best to match the colors in your shared theme to ExB. The "Button background" color in your shared theme will be picked to be "Primary" color in ExB, and the "Button text" color will match the "Dark" color in ExB. The "Body background" will match the Secondary color in ExB.
There is no way to match perfectly for different theme system. But you can manually adjust the app design to use the colors from your org shared theme. In color picker of EXB, you can see these colors from org. So you can decide where to use what color to match your shared theme.
And the logo in your shared theme cannot be read over, you have to manually upload it into ExB and use it in an Image widget
Wei_Ying
@JeffreyThompson2 Thanks for your feedback! Yes we have got similar request before and we are investigating this feature and will see if we can do in future release.
ShaneONeill_144
I would suggest getting in touch with your local Esri Distributor and ask them to investigate this further for you - it may be something that can be addressed by a bug/enhancement
Wei_Ying
JeffreyThompson2
MVP Frequent Contributor
Thought for future development: could you make it possible for Themes made in Developer Edition to be uploaded to Enterprise, similar to Widgets?
GIS Developer
City of Arlington, Texas
Wei_Ying
AnneReynolds
It seems I can no longer modify our organizational theme in Experience Builder ... only the default ones.  Is this a glitch?  7/2025
Wei_Ying
Organizational theme is always not editable from Experience Builder. ExB can only read over the colors and map to the current app from your organization setting
AndreaB_
@Wei_Ying What is the difference between the "Organization Shared" theme at the top
and the "Shared theme" at the bottom?
Wei_Ying
@AndreaB_ Good question!. You are opening an old app in new version after we upgraded theme system.
The old theme you used will always listed under "Your current theme" after the upgrade.
The top theme "Organization shared" is the old theme mapping from organization setting. And the bottom one is the new theme mapping from organization setting. They are both organization theme, but the bottom one is improved for theme variable mapping.
AndreaB_
@Wei_Ying Thank you! That's great info. We can try this out on our apps to see if the theme colors match our organization colors better.
