Experience Builder Edit Related Tables
19181
31
12-28-2022 01:19 PM
ChristopherBarrow1
Hi, I am trying to solve a tabular data issue in the ArcGIS Online environment.
I want any of my 4 or 5 users to be able to edit a coded list (domain).  When we add a new record, for example a work order in our work order table, and the requesting customer is not listed in the domain drop down list for the customer attribute, only I as the feature layer owner can go back to the data tab in the feature layer properties and add another customer in the coded list.
I have tried sharing the feature layer in a shared update group, and they can't edit it there.
The environment I am looking at for the front end is the experience builder edit widget, b/c it allows us to add a new record.  I have tried linking related tables together, but can't come up with a solution.
Does anyone have any ideas?  I am up for any solution, just as long as any user can still add a record.
Thanks.
Geraldine
Waw that's pretty ugly 😫 and I'm not sure it will work for me. The rooms have to be updated after a related record has been added, because behind the scenes I calculate a field of the rooms layer automatically (using the related records) to be able to symbolize them - so the users can easily make the difference between inspected and non-inspected rooms. Another - but slightly less - ugly workaround.
Thanks for the research anyway Laura. I guess I'll test this new 'related features' option in ArcGIS Online and hope it will be implemented in Portal 11.4 if it improves things a bit.
HDolley
Hi everyone,
Thanks for all the info here. I am looking at something similar in one of my experience maps - I but I am wondering if there is a way to jump to the related record from the table table widget?
It works in Map viewer like this when looking at the attribute table:
