Experience Builder doesn't obey ArcGIS Enterprise Sort Order
2220
7
02-06-2024 12:55 AM
Cory__Williams
I'm currently running ArcGIS Enterprise 11.2 and with the built-in XB, using the Basemap widget, I can pull the basemaps through from Portal, however they won't sort as per the sorting order set in Portal.
Are there any plans to enable this, or to have sort order set within the Widget itself?
TonghuiMing
@Cory__Williams You can choose the Custom mode and drag & reorder the needed basemaps.
Also, do you have some screenshots showing the differences between the widget vs. order set in the portal?
JwHayes
This issue existed in WAB too. The basemap widget always sorted the basemaps by name in ascending order. I hope this is something EB Basemap widget does not inherit. 🙂
TonghuiMing
I see. We will take a look and evaluate if that would be an enhancement in the future. Thanks for bringing this up.
JwHayes
Hi @TonghuiMing. Don't forget about us! 🙂
TonghuiMing
@JwHayes @Cory__Williams
Inside an org, items are sorted with a default criteria - date created descending:
Notice that they are added to the parameter so nothing is stored.
Is the date descending order the one that you'd like to see for the basemap order inside your groups?
TonghuiMing
The new sort option has been provided in the recent AGOL update:
Jay_Geisen
This issue still exists in Enterprise/Portal Experience Builder version 11.5.
