experience builder custom widget
1181
01-22-2024 01:19 AM
universalexb
hi, i have created a custom widget and in the initial load i need to show the arcgis portal login page. after successful login i need to redirect the page to my application. i have successfully don this in my developer version but when i am deployed this in my local server its not working. anybody have any idea?
actually the login process i have implemented in the custom widget is to get the current user's groups from portal. when i use
portal.load().then(function () {
              portal.user.fetchGroups().then(function (fetchItemResult) {}
i can get the group info in the developer edition, but when deploy it i am not able to access it. is there any way that i can get the userinfo from protal?
JeffreyThompson2
MVP Frequent Contributor
The props.user object available to all custom widgets should contain all of the information about the user on the Portal. props.user.groups should contain an array of all the groups the user is a member of.
GIS Developer
City of Arlington, Texas
