I have an experience builder page (ArcGIS Online) with text in the header which links to an anchored window with help information (screen shot below). When I click on the link, the window appears but then disappears again after 3 seconds (consistently 3 seconds). The same is happening for the other two links (Contact Us and Share)
I have the setting to 'Click outside window to close' checked. Screen shot of window settings below.
Am I missing a setting? How do I ensure the window stays open until the user clicks outside the window to close it?
I believe this is relatively new behaviour. It's not something I've noticed before, and I distinctly remember previously having to click out of the window to close it. It is happening both in the editor, and when viewing the published version of the experience builder.
Solved! Go to Solution.
We can confirm that this is a regression bug of the text hyperlinks and we plan to fix this bug in the next few days.
Until this bug is fixed, you can use button widgets (make sure the background and border are correctly set for both Regular and Hover) instead of these text widgets to link to anchored windows.
Shengdi
Hi @BlairPellegrino ,
My first thought was that it was caused by an autoplay section, as you describe it as "consistently 3 seconds". I tried a similar configuration, adding an autoplay section to both the page and the anchor window, but was unable to reproduce your issue.
Can you try to disable the Section autoplay (if there is one) and see if this issue still reproduces? If you don't mind, you can share your app with me, my username is she10946.
Regards,
Shengdi
Good thought. I've confirmed that the section autoplay is disabled for the content in that particular window. Interestingly, the same behaviour is happening for both the windows that are linked to the 'Contact us' and 'Share' text in the top-right, but neither of these contain sections.
I have just added you to the group.
Very keen to see if you have any other ideas.
Cheers,
Blair
Shengdi
Thanks @ShengdiZhang - good to hear you were able to identify the issue and that there's a fix coming soon. Look forward to hearing once the fix is in place
This bug should be fixed in today's update, please give it a try.
Thanks for the update @ShengdiZhang - it's working again now!
I have a hyperlink in my AGOL Experience. It says "Workshops" and it links to another page. I want it to say "Workshops and Events" but every time I edit it, the edits go away as soon as I click off it.
