Exp. Builder tables not loading since last night
6247
18
03-23-2022 06:20 AM
JoseBarrios1
Hello Everyone,
I was just wondering if anyone is also having problems with Exp. Builder not loading the data for the table widget. Since last night, all my application stop loading the data. The table frame is loading and I can export the data to a csv, but the table in exp. builder and the App is blank.. same is happening to all 5 applications.  Thanks for any suggestions!
JB
Jianxia
@ZhifangWang - could you help take a look?
ZhifangWang
@Teresa_Blader
The fieldworker/form view of a survey is designed only for collecting data, not for viewing or querying data. For the later purpose, you would want to use the _stakeholder/_results view or make a view of the source layer in your own.
You can find more information about these in https://community.esri.com/t5/arcgis-survey123-blog/securing-data-in-public-surveys-survey123-web/ba....
Teresa_Blader
Ok, That partially makes sense, except for this project purpose these data tables in EB has “allow editing”  and is actually being edited by the people who have access to “Update Survey” in Survey123 since we can rearrange the field orders in EB and not in Survey123. I don’t believe stakeholder/results is affected by the settings under Update Survey… so i think it does have to be based on the parent layer or a view with editing on doesn’t it?
the article doesn’t describe the “update survey” effects on the layers.
Teresa Blader
Olmsted County GIS
GIS Analyst - GIS Solutions
Junshan_Liu
Can you check whether there are any browser console errors?
ScottHiggins_PVGIS
In Experience Builder Dev 1.7, the console errors preventing an embedded survey from loading have to do with - Refused to display 'https://www.arcgis.com/' in a frame because it set 'X-Frame-Options' to 'sameorigin'
Junshan_Liu
This is the error related to survey. Do you see any errors related to table widget?
anonymous55
I can't embed survey123 either
Jianxia
@anonymous55 , There is an issue stopping non-public survey from embedding after the release last night. See details at https://community.esri.com/t5/arcgis-survey123-questions/embedded-form-in-dashboards-no-longer-openi...
by Anonymous User
Not applicable
Seeing same issues - able to add new record in embedded survey - not able to edit existing records - Survey123 imbedded into experience builder dev 1.7 - was working fine past months - We have many of these in use please fix the issue ASAP. these are production.
Error seeing in console is Cross site request/same site cookie issue - In Exp Builder "ArcGIS.com refused to connect"
