Exp. Builder tables not loading since last night
6238
18
03-23-2022 06:20 AM
JoseBarrios1
Hello Everyone,
I was just wondering if anyone is also having problems with Exp. Builder not loading the data for the table widget. Since last night, all my application stop loading the data. The table frame is loading and I can export the data to a csv, but the table in exp. builder and the App is blank.. same is happening to all 5 applications.  Thanks for any suggestions!
JB
TonghuiMing
This issue was then reported as a Tech Support issue and has been fixed in patch b.
TonghuiMing
@JoseBarrios1 Is it possible to share your app with us to take a look?
JoseBarrios1
unfortunately..the apps are for Organization use (federal) only! Sorry
TonghuiMing
We have found an issue with the table when there is a List widget with sort enabled if they share the same layer. Could you please help check if you have the same case?
Or, could you tell more about what your data structure/format is?
JoseBarrios1
Yes... in one App case. it does have a list widget on the same layer with sort enabled....the other App have the same issue with just filters
TonghuiMing
Teresa_Blader
Hello! I am also having this issue as of today. Is it possible there needs to be another patch or what should I do?
Teresa Blader
Olmsted County GIS
GIS Analyst - GIS Solutions
Jianxia
@Teresa_Blader , there hasn't been any update on the production since July. It might be browser cache or data changes. As a test, could you open the app in the incognito window?
Teresa_Blader
Thanks for the response! I didn't see an improvement with the incognito window or browser cache refresh. I added a few sheets, so the first one does load upon opening, but the other sheets do not. One did eventually load, but it took 45 seconds, but it doesn't seem to load every time I open the site. I have no problem loading the tables when in editing mode. All the layers are shared the same way, but I'll start digging around to make sure there's not something I'm missing, unless there's any other suggestion. There isn't any sorting on any of the tables either.
Teresa Blader
Olmsted County GIS
Teresa_Blader
It looks like, using the survey123 layers for the fieldworker/form does not work to display in the table when allow editing is enabled in Experience builder, but using the "parent" layer does. Even though the share settings are correct on the fieldworker layer..... however, every once in a while it loads. So that's weird!
Teresa Blader
Olmsted County GIS
