Exp. Builder Filters don't react to other elements on the same column.
2379
06-11-2021 10:34 AM
JoseBarrios1
The need: create several filters for a table and group filter by topic.
The approach: create several individual filters within a column, keep the first filter open and set each of the other filter to "collapse filter details"
The problem: filters layout don't react to other filter widgets when one is opened (see pic)
Are there is any way to accomplish this?
JB
2 Solutions
jcarlson
How are your filters being arranged? I can have multiple filters in a single Column container with their heights set to Auto, and this seems to work just fine.
ExpandedExpanded
CollapsedCollapsed
- Josh Carlson
Kendall County GIS
JoseBarrios1
I figured it out! My problem was that the "Height" on the size settings for each filter need to be set to "Auto"
JB
jcarlson
ExpandedExpanded
CollapsedCollapsed
- Josh Carlson
Kendall County GIS
JoseBarrios1
Thanks Josh for a quick reply!. That was exactly my problem. It is working now, however I noticed that the filter collapse back every time I select one element within each filter. Do you know if there is a setting to fix that?
JB
jcarlson
That, I believe, is a bug with the "collapse automatically" setting turned on. I've never been able to turn that setting on without the filter repeatedly collapsing while I try to work with it.
- Josh Carlson
Kendall County GIS
JoseBarrios1
JB
