ExB Feature Info Widget - How To Get Popups For All Included Layers At A Clicked Location?
2122
06-28-2024 06:18 AM
bdoventures
I'm testing the new version of the Feature Info Widget, and have added several layers, but no matter how I configure the settings, I cannot select a point on the map and view/browse all the popups for the selected features from the layers the way I can with standard popup functionality.  I have to go back and reclick on the map to get the popup from a different layer into the feature info panel.
Am I just missing something?  It seems like this functionality should go hand in hand with support for multiple layers when it's a standard feature of the popup tool.
jcarlson
Looks like you're right. I can't get my feature info to show anything but a single clicked feature from the map. The closest I can get is using the Select widget with a point selection. But even then, the Feature Info widget only shows the "1 of N" on a per-layer basis.
I can select 10 things across 4 layers, but I've still got to switch between layers in the feature info widget itself just to see all of them. Lots of clicking.
- Josh Carlson
Kendall County GIS
JeffreyThompson2
MVP Frequent Contributor
I don't have time to write up the full procedure right now, but I think I found a hack to turn Near Me into a popup replacement.
GIS Developer
City of Arlington, Texas
shodge_fsu
You might want to check this thread out to see if it does what you are looking for.
https://community.esri.com/t5/experience-builder-custom-widgets/identify-for-experience-builder-1-14...
Wei_Ying
If you'd like to see the selection only in Feature Info widget, you can use "Selected feature" view for the layer.
But for different selection on different layer, you have to switch the layer to view. It is not exactly like Popup where all features from different layers will show together.
We may enhance Feature Info widget in future to support exactly like popup. Sorry for the inconvenience.
Wei
