ExB Printing widget not accepting GP tool
2069
5
04-07-2023 09:56 PM
BlairMcclenathan
Like the title says, we have three GP tools that we have used for the past few years with no issues on other apps (built by a third-party consultant), but when trying to use them with ExB they will not work. I have added the utility as the organizational default and it does work at all custom sizes with New Map Viewer.
I have tried both adding the utility directly with the REST service link along with adding the item to AGOL and then attempting to add the utility to the print widget. The result with both is the PrintTask will be 'added' and the text "Click the “Select utility” button to add utilities for further configurations." returns right after.
Thanks!
ShengdiZhang
Hi @BlairMcclenathan ,
Can you send me one of the GP tools so I can take a look?
Shengdi
BlairMcclenathan
Here you go!
ShengdiZhang
At the moment, the print widget only supports print services that have both an export web map task and a get layout templates info task. We're planning to enhance this functionality in the next release, but we cannot guarantee a specific timeline.
JessicaRamirez1
I'm experiencing the same issue, I've checked my print service and it has both tasks: an export web map task and a get layout templates info task.
DanielWebb
Hi!
I'm running into this problem too. How do I publish a service with both `Export Web Map Task` and `Get Layout Templates Info`?
Thanks!
