Identify for Experience Builder 1.14
9117
20
05-29-2024 09:22 AM
This is an outdated version of this Widget. For Experience Builder 1.19 or higher, use this version.
This is an update to my previous Identify Widget to be compatible with Experience Builder 1.14. It is intended a replacement to the standard map popup and it is capable of being triggered by a map click or the included lightly modified Search Widget.
This version also fixes the previous versions dependency on setTimeout()* by adding another layer to the React tree specifically for waiting for the map layers to load and displaying a loading indicator. Results should render faster from a mouse click and on searches from a fast network and render more accurately if the network is running slow.
*I was not able to get rid of setTimeout() completely. It serves two functional roles in the widget. A one second timeout is called when a point comes in from the Search Widget. This allows for the map to start moving before setting the reactiveUtils to wait for the map to be still. Adjust this timeout if results from search are inaccurate or do not load. In the Identify.tsx, a .3 second timeout is called before passing the results to Results.tsx. This timeout allows for the data to be committed to memory before proceeding. Adjust this timeout if results are only loading the titles of the layer.
As in the previous version, you will need to find the widget_id  of the sidebar to make the auto-opening/closing work and put the widget_id of the Identify Widget into the Search Widget settings for the two widgets to interact.
Comments
shodge_fsu
This custom widget works great.  Just as advertised.  With some very minor editing to the results.tsx file we were able to drop the tabbed look and simply display all of the found data at one time, thus eliminating more clicks to see all of the results with just a scroll to see everything.
Many thanks to @JeffreyThompson2
PLadd
I know updates can break things.  I'm working with 11.3 and ExBdev 1.15.  I've incorporated the  Identify widget only (not the search) and all it does is close the sidebar.
I'm also confused about the widget ID.  If I poke around through the developer window in Chrome, it looks like the widget ID is 29 (and setting this makes the sidebar close).  But the image below says "This widget ID: 28" but if I use that, nothing happens when map-clicking.  Is this setup correctly or is it broken at 1.15?
JeffreyThompson2
MVP Frequent Contributor
@PLadd I am currently out on paternity leave and have not yet tested this widget in 1.15. I don't believe it should have broken. Make sure you are testing on Feature Layer. The id number in that box should be the id of the Sidebar Widget.
RichDeBell
@JeffreyThompson2  Hello I am trying to deploy this to an EXB app in Enterprise 11.3. When it is loaded into EXB builder the identify widget throws an error "Cannot read properties of undefined(reading '__set_webpack_public_path__'). Look at the browser console I can see 404 errors for widget.js and setting.js. The folder path for 'dist' inside the widget is totally missing which make sense given it's trying to hit the following subpath from root domain (widgets/identify-custom/dist/runtime/widget.js). Looking at the original download file I can see this is missing there whereas with the seach widget which works does have the 'dist' directory. Am I missing something with the deployment process? Thank you
JeffreyThompson2
@RichDeBell My Enterprise has not yet made the transition to 11, so I do not have any experience with doing an Enterprise deployment.
This code has not been complied by Webpack, so it does not have the dist folder. (The dist folder in the Search Widget should just be the ESRI code without my modifications.) I believe you need to first put these widgets into Developer Edition. Webpack should create the compiled code in the /client/dist/widgets folder. You should probably use the code from that folder in your Enterprise deployment.
RichDeBell
@JeffreyThompson2 OK thanks yes let me check into that
RichDeBell
@JeffreyThompson2  I assume both Identify and Search need to be compiled separately and not just from the folder they both are contained in. I think that's the issue likely
wliu
Many thanks to Jeffrey. And hi @shodge_fsu, it looks like your modified version is also very clear and useful. Could you share how you edited the code to create this more straightforward layout?
shodge_fsu
@wliu - The person who updated the code is no longer working for us.  I believe he edited both the result.tsx and the identify.tsx files.  I can't seem to find a way to attach the two updated files to this post so I direct messaged you with them.
Let me know if you have any issues getting the files.
wliu
The original code works well as advertised!👍 I have made several modifications to adapt the widget to my own needs. I would like to share the updated version here in case anyone needs similar functionalities.
Updates:
  • Instead of showing fueature layers' information in a tab view, a scrollable page view is applied.
  • Re-developed the Search Widget with ExB Developer Edition v1.15.
  • Upon a "click" event, instead of highlighting all selected layers, only allow one layer to be highlighted.
  • Remove empty results from the Identify's result panel.
(I'm working with ExB Developer Edition Version 1.15.0)
HeathAnderson
Hi @JeffreyThompson2 ,
Thanks for the app I was wondering if there is a way to enable the widget to respect the incoming url parameters? I can pass the attribute and value that selects the feature in the map but the widget will not populate unless the user clicks map.
Thank you
Heath
JeffreyThompson2
@HeathAnderson Take a look at this code for extracting info from URL Parameters. The sample should be modifiable to your needs. I would recommend using a separate URL Parameters Widget in this case instead of trying to extend this widget directly. I'm just not sure how what kind of re-renders and state issues you will hit if you try to do it inside this widget.
https://community.esri.com/t5/experience-builder-tips-and-tricks/starter-widget-for-getting-informat...
AdamGebhart
@JeffreyThompson2
Does the Identify widget work only on layers that have a popup configured in the web map?
I'm testing this out in Developer 1.19 (I've never tried it until now) and that's what I'm experiencing.  Also, in case it matters, I'm pointing to map service endpoints (I think ESRI folks refer to them as Map Image layers) and not a feature service or feature layer.
JeffreyThompson2
@AdamGebhart Identify was only designed to work with FeatureLayers. With a bit of refactoring, it could be made to work for the Sublayers in a MapImageLayer or you could load the layers to your Webmap as FeatureLayers.
AdamGebhart
@JeffreyThompson2 Thanks.  I've added my REST endpoints individually as opposed to the entire service.  The Identify widget populates but only if I click on a layer in which I've configured a popup in the web map.
Robert Scheitlin's Identify widget in WAB didn't require a pre-configured popup as you essentially create one (a list) through the Identify configuration window.  This has always worked great for us because we can set popups for only a few layers in the web map and avoid confusion for our users.  I'm just curious if yours does or does not require the popup in the web map first.
JeffreyThompson2
@AdamGebhart Yes, the layers will need a PopupTemplate created and enabled either in the Webmap, as part of the export configuration, or done programmatically.
AdamGebhart
@JeffreyThompson2 Thanks for the clarification.
JeffreyThompson2
The Search Widget included in this package is broken in 1.19. You should be able to fork a current copy of the ESRI Search Widget and make it functional again by adding a few lines of code based on this.
The included Search Widget is the standard ESRI Search Widget with three lines of code added to the result-list.tsx onSelectRecord() function. One of which is just an aesthetic UI improvement to close the search result panel after the user makes a choice.
//Extracts geometry from data source
const geometry = records[0].feature.geometry
//Closes search result panel
onShowResultButtonclick()
//Sends geometry to identify widget
MutableStoreManager.getInstance().updateStateValue(`widget_${props.config.identifyWidgetId}`, 'newSearch', geometry)
It extracts the geometry from the data source and sends it to the Identify Widget where it is converted to a screen point and triggers the rest of the identify functionality. This Search Widget was designed and tested using a Locator source. It should also work with a point type layer source. It will not function properly with non-geographic data or other types of geometries.
You will need to enter the Identify widget_id into the Search Settings Panel. It can be easily seen in the Identify Settings Panel. Because Identify relies on hitTest(), you must also use the Zoom To Action to ensure that the searched location is visible on the screen. You may need to use a custom zoom level as well. If you do not zoom into a features visibility range, the feature will not be displayed and won't be found by hitTest(). And hitTest() is, by design, not super precise and will find all features in a six pixel buffer around the actual screen point, so you may need to zoom closer than the default to prevent finding more features than desired.
I am working on a ground-up rebuild of this Widget to migrate it to Components and I'm hoping to make it triggerable by the @Brian_McLeer Draw Widget and other types of Search geometries, as well.
ncramer11
Can someone confirm if this custom widget works in 1.20? Thank you in advance.
JeffreyThompson2
@ncramer11 Not really, but I'm about to publish a new version. The Widget is complete. I'm working on a write up right now.
...And now it's ready. https://community.esri.com/t5/experience-builder-custom-widgets/identify-by-query/ta-p/1699614
Version history
Last update:
‎05-01-2026 02:00 PM
Updated by:
Contributors
