ExB Developer organization basemaps with EnterprisePortal "anonymous-portal-access disabled"
1030
03-13-2023 06:26 AM
AndreasEugster
When I publish a public-available Experience from ExB-Developer, our EnterprisePortal organization basemaps do not appear. Instead the Esri default basemaps are listed in the map-basemapgallery-widget.
The organization's basemap/gallery group is set to public, as is all the content/services it contains. Our Enterprise Portal is NOT accessible anonymously. Enabling the "anonymous access" in the org-settings would solve the problem (tested, org. basemaps appear) but due to security reasons we are not allowed to do so.
This question/problem has been mentioned several times and described as solved in the forum.... only I don't see any actual solution or statement about it anywhere... (#1044139, #1174539#M4401, #1019810, #162566)
  • Am I missing something, is it a bug?
  • Is it even possible with "anonymous portal access disabled" ...or not intended that way at all?
  • Are there any kown solutions / workarounds?
ExB-Dev Version: 1.10
Enterprise Portal: 10.9.1 (anonymous access disabled)
Would love to here your experiences or a statement from esri regarding that issue.
Cheers
TonghuiMing
@AndreasEugster This is the expected behavior with "anonymous portal access disabled".
TonghuiMing
AndreasEugster
The sweet satisfaction of closure 🙂
Thanks for the reply ! In the meantime we got the "standalone basemap widget" which can be used as a workaround / solution for our usecase since you can configure specific basemaps from portal (in our case the org-default-basemap-group and select all listed basemaps). But that only works if you are not required to use the "on-map-basemap-widget".
