Editor widget
2366
08-12-2024 07:45 AM
HafidaAttar
Hello,
I am using ArcGIS Pro and ArcGIS Online, but we don’t have ArcGIS Enterprise here. I’ve created an ArcGIS Experience Builder app with an editor widget that allows users to create, delete, and edit points. However, I'm encountering an issue: when creating a point, users need to select a class from a dropdown list of attributes. I would like to allow users to select a symbol and then create the point directly.
I know it was possible with smart editor form web app but I don’t know how can I achieve this with experience builder?
Thank you!
clt_cabq
I'm playing with the editing widget and when i add a layer it presents in the widget with a template based on how the layer is symbolized in the webmap it it is in - do you have yours symbolized? Also, are the editing capabilities set up correctly? The dialogue i see lets you select if users can add, delete, or update (attributes and/or geometry).
HafidaAttar
the layer its symboized according to the class, the editing capability its set to attribute and geometry, this is what i get when i want to create a feature: Picture1.pngPicture1.png
And this what im looking for :
Thank for your reply
Laura
by MVP Regular Contributor
Mine will also automatically let you click a symbol as shown in your 2nd image in EXB.
what do your settings look like?
What does the editing pane look like in map viewer? It should be pretty similar
AlixVezina
@HafidaAttar
You may need to update the editing feature templates to get the list of types to show a template for each class like you had it in Web AppBuilder Smart Editor, or like @Laura is showing above.
This is not intuitive right now, but you'll need to open your web map in the Field Maps Designer and make the template changes there. Follow the steps provided in this post:
Solved: Re: Edit Widget - Create Feature Order Won't Updat... - Esri Community
