Edit widget - field order bug?
1387
11-13-2024 07:06 AM
NeilWebber
Hi
I'm absolutely certain that yesterday I was able to manually drag-and-drop fields to re-order them in the Edit widget settings ('Configure fields' section) - just like you still can in the Table widget settings. Today I can't, and I'm looking very suspiciously at the fact that this has coincided with the overnight update to ExB that introduced a bunch of new features to the widget in question - particularly the ability to group fields together (i.e. messing with how fields are ordered and appear). This would be a nice new feature, but not if it breaks the ability to easily re-order the fields in each group.
Am I going mad and mis-remembering, or is this a new bug?
KathrynWalker
Hi @NeilWebber,
We are aware of this behavior and have BUG-000172230 logged for this issue. Please reach out to Esri Technical Support if you wish to be attached to the bug and follow along with its progress.
Thank you,
Katie
ChristineTombleson1
Has this bug been fixed?   The fields in my edit widget don't match my web map and I can't find configure fields to correct it.
KathrynWalker
Hi @ChristineTombleson1,
BUG-000172230 was fixed last November, and I have not been able to replicate the issue.
The ability to configure fields through the edit widget should appear if you have your data source connected to a web map. If the Edit widget's mode is Interact with a Map widget and Customer layers is enabled, you can select the arrow drop down to the right of your web map name and gear icon to see the layers within the map, or this capability should be available if mode is Attribute only and selected data type is a web map, not feature service.
Please let us know if you are seeing otherwise!
Thank you,
Katie
