EB version 1.5 Survey Widget error message: n is not a function
343
05-01-2026 08:12 AM
Bec
Hi!
I am using an older version of Experience Builder (1.5) in a Cityworks portal and have run into some issues when it comes to adding a Survey widget to a Widget Controller.  When I add the Survey widget to the Widget Controller, it will cause 3 areas of my EB to crash and displays the error message: n is not a function.  I get this error before even linking my survey to the Survey widget.  I have tried adding the Survey widget outside of the Widget Controller and get the same error.  I'm not sure what is causing this error message.  I have tried opening my EB in Edge, Chrome, and Firefox just to continue to get the same error message.  I have disabled the browser settings for local network access checks and still get the same issue.  Is this a known bug with this version of EB?  Any work arounds to get my two surveys to work within the EB?  Any help is greatly appreciated!
Bec
